Hackaday.io Hackaday.io
Sign up Log in
ESP8266 Game
A gameboy like board for the ESP8266 with OLED, Sound, Analog Joystick, and 4 action buttons!
daniel-johnsonDaniel Johnson
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
10.4k views
13 comments
39 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 12
    • View all
  • Logs 4
    • View all
  • Instructions 0
  • Discussion 13
View Gallery
10.4k
13
39
30
Team (3)
  • daniel-johnsonDaniel Johnson
  • hadibashnijihadi.bashniji
  • celso-caldeiraCelso Caldeira
Join this project's team
completed project
hardware
ESP8266 game gameboy game-boy
Related lists
Video Games
Both retro and novelty. Games, consoles, controllers, gadgets.
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 12/12/2015 and last updated 6 years ago.
Description
I started this project because I thought it would be very cool to create a game-boy out of the ESP8266 where people can utilize any of the ESP8266 libraries such as the Arduino IDE to create retro and modern monochromatic games. Since an ESP8266 is used that means WiFi capability is built right in meaning games can be made multiplayer whether local or over the Internet. Another goal was to make this as small as possible and something that could easily fit in your pocket. the unit itself is only slightly bigger than 3 AA cells and in the future versions will fit this form factor as well as offer more features such as built in lithium battery charging and built in USB programmer.
Files
ESP8266-Game.zip
Source Code
Zip Archive - 73.46 kB - 03/04/2021 at 18:21
Download
Components
  • 1 × PCB
  • 1 × ESP8266-12(e)
  • 1 × SSD1306 Display
  • 1 × PSP1000 Joystick
  • 4 × 0805 10K Resistors
View all 12 components
Project Logs
Collapse
  • ESP8266-Game Plays Super Smash Bros. !!!
    Daniel Johnson • 12/20/2015 at 08:19 • 0 comments
    I will be making an actual super smash bros that's multiplayer over the ESP8266 Wifi and that plays on the ESP8266-Game's Screen. Similar to the port that's been done on the TI calculators.
  • PC Controller
    Daniel Johnson • 12/19/2015 at 18:16 • 0 comments
    Lately I've been working on using the ESP8266-Game to be used as a WiFi controller for my PC and so far I've got it working. Once I get the code polished up I will be releasing it as well.
  • PCBs
    Daniel Johnson • 12/12/2015 at 09:07 • 0 comments
    The PCBs have arrived and I have built the first one and it works!!!!
  • Prototype Phase
    Daniel Johnson • 12/12/2015 at 09:03 • 0 comments
    An overview of the prototype.
    Playing Pong
View all 4 project logs
Log In/Sign up to comment
Sign up with Github
OR
Cppppy wrote 11/24/2021 at 15:26 • point
Hi, can you tell me which.ino file is for wireless game controller? I don't really understand
[deleted]
Daniel Johnson wrote 07/07/2017 at 06:13 • point
i think this is the only thing i published. http://cracked-ice.com/Downloads/ESP8266/
panosssj4 wrote 07/02/2016 at 21:03 • point
Can you reupload the code for the controller because cracked-ice.com is down?
Daniel Johnson wrote 10/31/2016 at 04:47 • point
website is back up. don't know for how long. been real busy with school lately and server is being hosted at a friends house and i don't regularly update the DNS like i should
pRoFiT wrote 04/24/2016 at 06:46 • point
Nice i was just thinking along the same lines of using the ESP for a wireless controller. I really want to build a couple units with like 4 buttons so they could be used for PC Trivia game. i found an SDK called vJoy that i was going to use for it. But maybe your code completes even more of what i was looking for by having the ESP communication built in. Thanks! Now off to find a good trivia API to use.
edit: just opened the ino file. 1000 lines of code. nice.
Daniel Johnson wrote 04/25/2016 at 07:23 • point
most of those lines of code are copy and paste for the screen.
Craig Hissett wrote 04/07/2016 at 11:31 • point
This is great - the creation of the PC script just takes this on to a completely different level.
I've only just started getting to grips with the ESP chips, but I need one of these in my life ha ha!
Great stuff man!
Ulrich Norbisrath wrote 02/04/2016 at 10:09 • point
Hi there. Nice project! A friend and I are also tinkering with the esp8266 (board similar to the Adfruit Huzzah) and an Arduino to turn it in some kind makey-makey like game controller (sorry, we can actually do our own PCB boards). Can you tell us a little bit or provide some links/references about the software you use or is all written yourself?
Daniel Johnson wrote 02/04/2016 at 18:32 • point
sure thing. i can send you the code. i must warn you it is a bit cluttered. i've been meaning to clean it up but i have been busy with school. i didn't interface it with an arduino however i only used an esp8266 standalone so i wont be able to help you with AT commands or anything because im not familiar and probably won't become familiar with them.
Daniel Johnson wrote 02/04/2016 at 18:34 • point
here's the link to my code http://cracked-ice.com/Downloads/ESP8266/ESP8266Controller.zip
Ulrich Norbisrath wrote 02/05/2016 at 06:34 • point
Thanks so much - digging into it - was thinking about starting some small OS project which could be easily embedded into your own games (some kind of mini udp server eating directional control commands), but will now look at your code and see if it changes my direction.
Ulrich Norbisrath wrote 02/05/2016 at 06:42 • point
Nice, am I right that you are actually taking the events from the esp and then faking mouse events on the windows pc? And you also set up a UDP server ;-) TCP has too much latency?
Daniel Johnson wrote 02/06/2016 at 11:22 • point
exactly. the ESP8266 just sends out the status of its controls and all
the meat is done in the program. just fakes the mouse events and stuff.
took a bit of time to get right to work with games using directx but in
the end i got it all working
Exactly as the title says, I built a bluetooth controller out of a SNES controller and dongle for use with Nintendo's mini classic consoles.
Project Owner Contributor
DIY Bluetooth SNES Classic Controller
sjm4306sjm4306
Think Neo Geo MVS 4 Slot, then think Super Nintendo Entertainment System. Put 'em together and you've got yourself a Super Famicade.
Super Famicade - Hardcore SNES Arcade Hack
dackrDackR
A project to create a device that utilizes HID protocol to operate as a media controller pad
HID Media Controller Pad
david-cainDavid Cain
This project is about creating a gaming controller system that combines a locomotion system, hands exoskeleton, head tracking and aiming
Gaming controller:locomotion,hand,aim,headtracking
marcob2178marcob2178
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "ESP8266 Game", please tell us the reason.
Send message
Remove Member
