Well, starting to put together the second half. I modified the main frame to add a motor mount. Both motors now on and working. Going to be awhile before this goes much farther, I have a lot of parts to print! 16 of the triangles at 33 minutes each, and most of the gears for this half still to go. The gears are mostly around 4 to 5 hours each, and I need 4 more of them. Yeah, slow going right now...
