Buckster
A buck and boost converter for lithium polymer and lithium Ion batteries. Small board to handle power requirements of a hand held device.
Buckster is both buck and boost converter. It also has circuitry to charge the battery over USB. It supports lithium polymer and lithium Ion batteries. It provides 3.3v and 1.8v output voltages.
DeepSOIC wrote 12/15/2015 at 12:29 • point
Hi!
"The 3.3v and 1.8v can be combined to produce 5V output as-well."
By that, do you mean connecting them in series? if so, how is that supposed to work? I see no isolation on your pcb, so the supplies probably share ground, so attempting to connect them in series will simply short out one of the channels...
Sandeep Patil wrote 12/15/2015 at 12:38 • point
Yes  you're correct, had not though through. It will not work, will correct it. Have just sent the board to fab for a proto. Thanks!
