We have tried to create a TCP socket, but this hasn't worked out.
import socket
import sys
import struct
import time
#main function
if __name__ == "__main__":
host = "192.168.16.100"
port = 22
#create an INET, STREAMing socket
try:
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
except socket.error:
print 'Failed to create socket'
sys.exit()
print 'Socket Created'
try:
remote_ip = socket.gethostbyname( host )
s.connect((host, port))
except socket.gaierror:
print 'Hostname could not be resolved. Exiting'
sys.exit()
print 'Socket Connected to ' + host + ' on ip ' + remote_ip
def recv_timeout(the_socket,timeout=2):
#make socket non blocking
the_socket.setblocking(0)
#total data partwise in an array
total_data=[];
data='';
#beginning time
begin=time.time()
while 1:
#if you got some data, then break after timeout
if total_data and time.time()-begin > timeout:
break
#if you got no data at all, wait a little longer, twice the timeout
elif time.time()-begin > timeout*2:
break
#recv something
try:
data = the_socket.recv(8192)
if data:
total_data.append(data)
#change the beginning time for measurement
begin=time.time()
else:
#sleep for sometime to indicate a gap
time.sleep(0.1)
except:
pass
#join all parts to make final string
return ''.join(total_data)
#get reply and print
print recv_timeout(s)
#Send some data to remote server
massage = "I'm here!!!"
try :
#Set the whole string
while True:
message = recv_timeout(s)
s.send(massage)
print message
print massage
time.sleep(1)
print 'Sending...'
#Send failed
print 'Send failed'
sys.exit()
s.close()
