//GPS
#include <SoftwareSerial.h>
#include <TinyGPS.h>
//LCD
#include <LiquidCrystal.h> //Inclui a biblioteca do LCD
//Servo
#include <Servo.h>
//Defines
#define GPS_TX 2
#define GPS_RX 3
#define LCD1 13
#define LCD2 12
#define LCD3 11
#define LCD4 10
#define LCD5 9
#define LCD6 8
//#define LUZ_FUNDO 6
#define MOTORPIN 6
#define POWERPIN 5
#define GPSRATE 9600
#define SERIALRATE 115200
#define LATDESTINO -18.919555 //UFU LATITUDE
#define LONDESTINO -48.256945 //UFU LONGITUDE
//#define LATDESTINO -18.885643 //Teste LATITUDE
//#define LONDESTINO -48.256570 //Teste LONGITUDE
//#define LATDESTINO -18.885277 //Teste mto proximo LATITUDE
//#define LONDESTINO -48.255819 //Teste mto proximo LONGITUDE
#define PROXIMIDADE 10 //Quantos metros para abrir a caixa.
#define buzzer 4
#define compasso 1500 //Altera o compasso da música
#include "pitches.h"
const int gameover[] = {
NOTE_A4,NOTE_A4,NOTE_A4,NOTE_A4,NOTE_A4,NOTE_A4,NOTE_A4,NOTE_A4,NOTE_A4,NOTE_A4,NOTE_A4,NOTE_A4
const int tempo_gameover[] = {
8,8,8,8,8,8,8,8,8,8,8,8
//GPS
TinyGPS gps;
SoftwareSerial serialgps(GPS_TX,GPS_RX); //TX -> 2(amarelo), RX -> 3(Verde), Vermelho -> 3,3
int year;
byte month, day, hour, hour1, minute, second, hundredths;
unsigned long chars;
unsigned short sentences, failed_checksum;
long previousMillis = 0;
long interval = 5000; //Set 10000
float DLA = 0;
float DLO = 0;
float DistDestino = 0;
float DistMax = 10000;
//Servo
Servo motor;// Motor de 10 à 130
//LCD
LiquidCrystal lcd(LCD1, LCD2, LCD3, LCD4, LCD5, LCD6); //LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
unsigned long UtlTime;
void setup()
//GPS
//Serial.begin(SERIALRATE);
serialgps.begin(GPSRATE);
//Serial.println("Print no serial");
//Servo
//motor.attach(MOTORPIN);
//LCD
lcd.begin(16, 2);
lcd.setCursor(4,0);
lcd.print("Procura");
lcd.setCursor(4,1);
lcd.print("Tesouros");
delay (5000);
//lcd.clear();
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" Aguardando GPS ");
delay(1000);
void loop()
motor.write(10);
delay(350);
motor.detach();
while(1)
//INICIO GPS
while(serialgps.available())
int c = serialgps.read();
if(gps.encode(c))
float latitude, longitude;
gps.f_get_position(&latitude, &longitude);
gps.crack_datetime(&year,&month,&day,&hour,&minute,&second,&hundredths);
gps.stats(&chars, &sentences, &failed_checksum);
if (millis() - previousMillis > interval)
previousMillis = millis(); // remember the last time we blinked the LED
DLA = LATDESTINO - latitude;
DLA = (DLA*60)*1852;
DLO = LONDESTINO - longitude;
DLO = (DLO*60)*1852;
DistDestino = sqrt((DLA*DLA) + (DLO*DLO));
if (DistDestino < DistMax)
//lcd.clear();
lcd.setCursor(0,0);
lcd.print("Distancia: ");
lcd.setCursor(4,1);
lcd.print(" ");
lcd.setCursor(0,1);
lcd.print(DistDestino,1);
lcd.setCursor(10,1);
lcd.print("metros");
if (DistDestino < 10000)
DistMax = 10000;
else
DistMax = DistMax + 10000;
while(DistDestino < PROXIMIDADE)
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Voce chegou!!!");
//Tocar som.
for (int Nota = 0; Nota < 12; Nota++) {
int tempo = compasso/tempo_gameover[Nota];
tone(buzzer, gameover[Nota],tempo);
delay(tempo*1.25);
delay(7000);
lcd.setCursor(0,0);
lcd.print("Lembra do nosso ");
lcd.setCursor(0,1);
lcd.print("primeiro beijo? ");
delay(5000);
lcd.setCursor(0,0);
lcd.print("Foi bem aqui ");
lcd.setCursor(0,1);
lcd.print("nesta esquina...");
delay(5000);
lcd.setCursor(0,0);
lcd.print("Como mudou esse ");
lcd.setCursor(0,1);
lcd.print("lugar, neh!? ");
delay(5000);
lcd.setCursor(0,0);
lcd.print("Como nos mudamos");
lcd.setCursor(0,1);
lcd.print("tambem... ");
delay(5000);
lcd.setCursor(0,0);
lcd.print("E mudamos para ");
lcd.setCursor(0,1);
lcd.print("melhor, certeza!");
delay(5000);
lcd.setCursor(0,0);
lcd.print("Chegou a hora de");
lcd.setCursor(0,1);
lcd.print("mudar denovo!!! ");
delay(5000);
lcd.setCursor(0,0);
lcd.print("Chegou a hora do");
lcd.setCursor(0,1);
lcd.print("proximo passo!!!");
delay(5000);
lcd.setCursor(0,0);
lcd.print("Abre-te sesamo! ");
lcd.setCursor(0,1);
lcd.print("=D, linda!!! ");
delay(5000);
//Inicio abrir a caixa.
motor.write(170);
delay(350);
motor.detach();
//Fim abrir a caixa.
if(day<=9)
lcd.setCursor(0,1);
lcd.print("0");
lcd.setCursor(1,1);
lcd.print(day, DEC);
else
lcd.setCursor(0,1);
lcd.setCursor(2,1);
lcd.print("/");
if(month<=9)
lcd.setCursor(3,1);
lcd.print("0");
lcd.setCursor(4,1);
lcd.print(month, DEC);
else
lcd.setCursor(3,1);
lcd.setCursor(5,1);
lcd.print("/");
lcd.setCursor(6,1);
lcd.print(year, DEC);
lcd.print(" ");
hour1 = hour - 3;
if(hour1<=9)
lcd.setCursor(11,1);
lcd.print("0");
lcd.setCursor(12,1);
lcd.print(hour1, DEC);
else
lcd.setCursor(13,1);
lcd.print(":");
if(minute<=9)
lcd.setCursor(14,1);
lcd.print("0");
lcd.setCursor(15,1);
lcd.print(minute, DEC);
else
delay(1200000);
motor.write(10);
delay(350);
motor.detach();
DistDestino = PROXIMIDADE + 1;
lcd.clear();
Thomas
