Hackaday.io Hackaday.io
Sign up Log in
DIXI watch - SAMD11
Take out maximum from super small arduino compatible ARM microcontroller
bobriciusbobricius
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.9k views
8 comments
14 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 8
    • View all
  • Instructions 0
  • Discussion 8
  • The 2018 Hackaday Prize
View Gallery
1.9k
8
14
21
Team (1)
  • bobriciusbobricius
Join this project's team
ongoing project
2018hackadayprize
Related lists
2018 THP: Digikey Parts
Hackaday Prize entries using Digikey parts
2018 THP: Microchip Parts
Hackaday Prize entries using Microchip parts
This project is submitted for
  • Open Hardware Design Challenge
  • Tell Time Contest
This project was created on 03/14/2018 and last updated 8 years ago.
Description
compact4014 charlieplexed led displayextra thinARM mcu samd11c14arduino compatiblenative usbbuilt in USB connectorwhy sam D11 ?? soic14 ...is really easy for solder small package powerful arm M0 core arduino IDE supported native usb Recommend use Mattair tech Arduino core and bootloader https://github.com/mattairtech/ArduinoCore-samd if you want full featured product or If you want support please buy boards from https://www.mattairtech.com/
Project Logs
Collapse
  • Firts board assembled
    bobricius • 06/20/2018 at 22:20 • 0 comments
  • Finished and ordered 3014 boards
    bobricius • 05/15/2018 at 20:23 • 1 comment
  • New 3014 board with 4 digits
    bobricius • 05/03/2018 at 13:06 • 0 comments
    I am little redesigned board. think that is very effective, all free space is used and board can be used as watch module for any enclosure with user programming capability .
  • RTC working
    bobricius • 04/16/2018 at 22:17 • 0 comments
    I am surprised RTCZERO library for D21 working without changes, time is measured with acceptable precision. also work sleep and ad wake on alarm match. Sleep consumption is about 5uA.
    Is time to start work on new PCB with full 4 digits display and maybe with 3014 leds
  • wav !!!!
    bobricius • 03/29/2018 at 23:03 • 0 comments
    Something working ;) Lights are on, beeper beeping ;)
  • wav !!!!
  • First board assembled
    bobricius • 03/29/2018 at 22:08 • 2 comments
    yes, all is good on place, it is time to make software
  • Received boards
    bobricius • 03/29/2018 at 21:22 • 0 comments
View all 8 project logs
Log In/Sign up to comment
Sign up with Github
OR
Matej wrote 08/06/2020 at 12:28 • point
Can you share the source code for this?
bobricius wrote 08/07/2020 at 11:57 • point
I have no code finished
josephchrzempiec wrote 06/05/2019 at 17:10 • point
hello which crystal are you using on the D11? Also where can i find one at?
deʃhipu wrote 04/14/2018 at 20:45 • point
What are you planning to use for power? Are you going to use the internal RTC of the SAMD11? I wonder if a micro-USB connector similar to the one at https://hackaday.io/project/28516-business-card-gamepad wouldn't work better here.
bobricius wrote 04/14/2018 at 21:16 • point
This test board is designed for CR2032, new board maybe with 3V Supercapacitor 5F I have plan use this connector in future but it need thin board and with this size it can be fragile.  I am using internal RTC and RTCzero library for samd21, alll work without changes + working sleep, wake on alarm match and wake on external interrupt = button. I need samd11 alternative for ReadVcc() function in atmega328. There is only 7GPIO for all leds, buttons and buzzer. Standby consumption is only 5uA. RTC precision is GOOD. I want use 3014 leds, they are exists in all colors, readability is good, tested on PyBox + replace connector on edge like in PyCard
deʃhipu wrote 04/14/2018 at 21:32 • point
Hmm, I vaguely remember there was a trick in atmega where you could measure internal reference voltage against the vcc, and calculate the vcc from that, but I can't recall the details...
bobricius wrote 04/14/2018 at 21:39 • point
Yes, on atmega it working good, arm is for my very complicated to found similar function. It is important for supercapacitor powering, it save IO pin and also save R divider.
Yann Guidon / YGDES wrote 03/17/2018 at 17:04 • point
4014 \o/
2021 Hackaday Prize
Maybe you are asking! Are we done yet with Arduino, hummm then let me tell you that we have just started because the Pro board is here.
Project Owner Contributor
Customized Host Board for Arduino Portenta
diy-guy-chrisDIY GUY Chris
ATtiny-based, Surface-mount, 5x7 dot matrix LED board
Nova SMT Blinky
bob-coggeshallBob Coggeshall
A development board for the ATtiny84a which can be used on a bread board. Just all the basics to run the micronucleus bootloader.
ATtiny84a tiniest development board
sander-van-de-borSander van de Bor
This is the second iteration of my AVR watch
AVR Watch v2
joe57005joe57005
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "DIXI watch - SAMD11", please tell us the reason.
Send message
Remove Member
