It's all coming together...
A project log for Mr. Runner
Creating a four legged robot with a running bound gait.
alex-martinAlex Martin • 09/08/2016 at 01:52•1 Comment
Just submitted an order to @oshpark!
This board is based off the incredible Botboarduino by Lynxmotion (http://www.lynxmotion.com/c-153-botboarduino.aspx). It has some features removed (speaker, some IO etc), and some features added. The new additions are:
- Current sensing (ACS715)
- Bluetooth (BlueSMIRF)
- Juicier battery traces with ring terminal connectors
The premise of the design was to keep the components as tight as possible (hence mostly surface mount), have the servo connectors / power connectors on the same side, and the USB connector opposite to the servos / power. This board will be mounted in the rear body of the robot (not much space!) so it needs to be concise and well organized.
Schematic:
Board view:
I got lucky and the design was sent off the fab immediately after it was submitted, so the boards should be here in around a week. Alright!
oshpark wrote 09/22/2016 at 06:31 • point
Awesome project!  We look forward to future updates
