Hair Dryer Fume Extractor
A ventilation system that sucks the soldering fumes and delivers the fumes outside.
Inspired by: https://youtu.be/lSaFpzxNR-I
The fumes that go out when soldering is the problem.
One solution is to suck the fumes through a cheap carbon filter but I don't trust the filters.
I think it's better to take the fumes out of the house. The guy on the video does it with a hair dryer, some pieces of vacuum cleaner hose and a cone.
I liked the idea using a hair dryer as an engine.
I can't install the hose permanently so my ventilation system needs to be portable. That makes it harder.
  • 1 × Hair dryer [ ]
  • 1 × Hose [ ]
  • 1 × Various water bottles to use as cones [ x ]
  • 1 × Something to keep the system steady [ ]
puwhqgsjzbwi wrote 09/23/2024 at 03:51 point
Shaving can cause razor burns, ingrown hairs, and cuts, while waxing often leads to temporary pain and redness. Laser hair removal, on the other hand by morpheus8 toronto , is gentler on the skin, and as the hair becomes finer with each session, it reduces the chance of irritation or other skin issues over time. Many clients experience a smoother texture with less inflammation.
