Here's the schematic and code for the boots- it's pretty simple. The Sharp IR sensor inputs a value into the Arduino which triggers the Luxeon boot lights and the WaveShield to play an audio file.
A larger version can be seen here.
Here's the code-
// these constants won't change:
int triggerSensor = 1; // the sensor is connected to analog pin 1
int threshold = 750; // threshold value to decide when the sensor input triggers
int ledPin = 3; // control pin for LED
int soundPin = 2; // control pin for sound board
// these variables will change:
int sensorReading = 0; // variable to store the value read from the sensor pin
void setup() {
Serial.begin(9600); // use the serial port
pinMode(ledPin, OUTPUT); // sets the LED pin as an output
pinMode(soundPin, OUTPUT); // sets the sound pin as output
digitalWrite(ledPin, LOW); // turn off LED
digitalWrite(soundPin, LOW); // turn the sound off
void loop() {
// read the sensor and store it in the variable sensorReading:
int val = analogRead(triggerSensor);
// if the sensor reading is greater than the threshold:
if (val >= threshold) {
Serial.println(val);
digitalWrite(soundPin, HIGH); // turn the sound on
delay(10); // wait ten milliseconds
digitalWrite(ledPin, HIGH); // turn the LED on
delay(2400); // wait two seconds
digitalWrite(ledPin, LOW); // turn the LED off
jeromekelty
