The inspiration for this project came from the desire to create something that would explore topics of Computer Science and Cyber Security. It also stems from the want to create a cheap tool that could be used for hackers. Essentially a inconspicous, droppable hack box. One that can perform common pen-testing attacks. Ones like, Wifi-Hacking, Bluetooth-Attacks, Password Cracking, Metasploit, and much more. The most important aspect of this project is its ability to perform well enough to be used as a simple tool for a hacker. This PC specifically, has the entire "Laptop Style," with a screen, keyboard, and even onboard battery. The main computer is a Raspberry Pi that runs Kali Linux (a popular linux distro for penetraion testers). This all works to create the "pi-Box," the cheap, portable, and capable PC that can be used by hackers, penetration-testers.
Hey I was just wondering if you could send me links to the parts/instructions you used? I tired using the link to your website, but an error came up in which the DNS server couldn't be found; thanks in advance! :)
Hey Granit, If you want to find the source of all the parts, check out my website here: http://www.kilicmuhammed.com/lunchbox-computer/ . There is also a lot of info on the build process and more! Let me know if you need anything else!
http://www.quickmalware.com/check-exe -ile is-bindded-or-not Check Exe File is Bindded or not
