The left paw was the problem, today. Yesterday's right paw issue was caused by a rock, not a shoelace end. Today's issue was chafing from the left heel being too tight & compression of the foam. The foam compressed a lot more than normal shoe foam, under the forefoot. It was pretty rough, near the end. Not sure how barefoot runners do it. Compression was a bigger problem than loss of material.
Made the toe strap loop back to the heel, to eliminate any knot issues. Used a bowline to tie the toe end & a half hitch to tie the heel end. Half hitches may be enough for everything. There's definitely a need to adjust, as chafing flares up & the toe flap starts flopping. Would make the lace only go one pass around the heel & use separate laces for the toes & heel. Having a bunch of knots where a shoelace would normally be tied hasn't been a problem.
Plastic squares succeeded in protecting the foam from loops.
Well & truly crushed in only 17 miles. Would say they did their job in proving the concept of lions running in sandals. The next step would be finding better materials for a reasonable price.
