Glow rope made a return for just the heel section. This didn't cause any problems & was easier to adjust the tension on. Something must be done about the rope wear. Tried the toe knot again & failed. If it didn't come undone on its own, it was real painful. 6.4 miles later, the soles were deemed worn down enough to discard. They lasted 25 miles, but there should be a test to destruction.
Gradually increased the speed up to 10.9mph.
It was definitely easier than shoes.
