It held up nicely, after 7 miles. It was like running on tin cans. The Loctite Metal did release near the flexing point, but it probably wasn't worse than hot glued plastic.
Fabrication involved a lot of drilling. Drilling holes bigger than 1/8" in titanium must be avoided. This process could probably be done with V cuts & grinding. Grinding titanium causes dramatic work hardening, but it hasn't been a problem for this application. That was all the titanium the lion kingdom can afford, for a long time.
Heat was the last remaneing problem with the laces. The resulting sweat would dry & attack the achilles tendon. After 11 miles in 90F, the 1/8" string solution didn't chafe anything. They could be any tightness. The farsteners were easy to adjust. Replaced the orange ones with black ones to make the toe plugs tighter.
