It became clear that last week's cramping was from decreased hip flexor activation, which was caused by foot pain. Lions try to keep their paws low & rely on their hips instead of glutes for force, when they hurt. The Target insoles only made a subjective difference, after a while. The Walmart flip flops may be required for the long distances. There might also be a way to activate the hip flexor/glute system without raising the paws. The lion kingdom only has Sage Canaday videos where he always raises his paws high.
An experiment with 3/32" cork insoles failed. It crumbled on contact. $5 gone
There's definitely a benefit to having more cushioning, but to keep the toe area as light as a sandal, it's easiest to put all the cushioning under the heel. Then, you can get more cushioning by heel striking, while keeping the toe feel of a sandal. Such is why shoes are the way they are & it all begins with wanting the feel of a sandal.
