PCB Elements and Features
A project log for M.O.S.A.I.C. LS
Modular Open Source Adjustable Intelligent Control Lighting System
slisgrinderslisgrinder • 03/24/2018 at 23:31•0 Comments
PCB Layout...
There was some back and forth about how many layers the PCB had to be. For keeping things cheap, the obvious choice would have been to use a 2 layer board. However, there needs to be a balance between being cheap and being simple. Sometimes to be simple you have to be a bit "anti-simple". The decision was then made to use a 4 layer board as it has significant benefits:
Gerber Top Render
Figure 1: Gerber top render
Gerber Bottom Render
Figure 2: Gerber bottom render
The PCB stack up is as follows:
Gerber Top Layer Render
Figure 3: Gerber top layer render
Top Layer
- Contains all the electronic components
- Poured as "+V" to provide a large current path for adjacent cells
Gerber Signal Layer 2 Render
Figure 4: Gerber signal layer 2 render
Signal Layer 2
- Contains 3.3V distribution and PWM control traces.
- Poured as "+V" to complement the Top Layer plane.
Gerber Signal Layer 3 Render
Figure 5: Gerber signal layer 3 render
Signal Layer 3
- Contains all RS485 and UART lines interconnecting the 3x edge connectors.
- Poured as "GND" to provide a large current return path as well as thermal distribution plane for the LEDs.
Gerber Bottom Layer Render
Figure 6: Gerber bottom layer render
Bottom Layer
- Poured as "GND" to complement the ground plane in the previous layer as well as a uniform thermal plane for heat sinking.
PCB Features...
The PCB has pads attached to the "+V" and "GND" plated M3 screw holes to allow up to 12 AWG wire to be directly soldered. With the help of the large power planes in the board, there is no need to have external power distribution between cells. The pads are identical on the bottom layer and enable various mounting options such as carrier boards, spring contacts, direct wire to board soldering, etc.
The I/O connector is symmetrical in design. It can be used in any orientation with other cells and facilitates the use of wires, flat cables, headers, spring contacts or direct "butt" joints with adjacent cells. Power can either be applied with the screw hole pads or the I/O connector. When assembled as an array, it is recommended to use the screw hole pads for the initial power entry into the array and the I/O connectors within the array.
Power Pads
Figure 7: Power pads
