Unfortunately, the AP63205WU (the buck converter to go from +12 to +5V) is out of stock everywhere and it appears like it won't be back in stock during 2022. Go figure.
I use this chip in a lot of things, it turns out, so I'm screwed.
In some cases, I can substitute an AP1509, but it's a SOIC-8 instead of a SOT23-6 and does not include a synchronous rectifier, so it means adding a Schottky diode to the circuit. There just isn't room for all of that on OpenEVSE II.
I'll post back when the 63205 becomes available again. But for now... I'm out.
Nick Sayer
