Hackaday.io Hackaday.io
Sign up Log in
clock and temperature
clock and temperature 7segment display
tntvladtnt.vlad
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2k views
0 comments
1.8k followers
  • Description
  • Details
  • Files 0
  • Components 2
    • View all
  • Logs 3
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
2k
0
1.8k
9
Team (1)
  • tntvladtnt.vlad
Join this project's team
pic clock temperature RTC 7 segment
Related lists
Clocks, clocks, and more clocks
If it has a timekeeper, it belongs in this list!
This project was created on 04/21/2014 and last updated 2 years ago.
Description
real time clock and temperature sensor display on 7segment display with pic microcontroler
5 seconds displays clock, 5 seconds temperature
with PIC 16f875A and LM335
Components
  • 1 × PIC16F876A Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × LM335 Power Management ICs / Switching Regulators and Controllers
Project Logs
Collapse
  • 7segment
    tnt.vlad • 07/17/2014 at 17:46 • 0 comments
    70 mm 7segment red, glued together behind of a acrylic, with 2 led for hour minutes separator
    I`m starting working for PCB design
  • Temperature reading done
    tnt.vlad • 04/21/2014 at 16:46 • 0 comments
    done the code for adc reading  with signed int and a little mathematics. Now it is time to wait for the parts
  • code phase
    tnt.vlad • 04/21/2014 at 10:38 • 0 comments
    clock done, display data done, temperature reader working...
View all 3 project logs
Log In/Sign up to comment
Sign up with Github
OR
A vintage 1956 pinball backglass becomes a word clock.
Project Owner Contributor
Harbor Lites Wall Clock
randy-elwinRandy Elwin
Dual NeoPixel Ring Clock shows hours, minutes and seconds with concurrent digital display. Time set via Internet. Shows temperature too.
Internet Connected NeoPixel Clock
spudnut1spudnut1
Multifunctional clock based on ESP8266 and WS2811 addressable LEDs for Home Automation (IoT)
LED Pixel Clock (Clock, alarms, temperature etc.)
led-lightwellLED Lightwell
wifi and temperature clock.
PCB Led display wifi clock
ledboyLedboy
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "clock and temperature", please tell us the reason.
Send message
Remove Member
