Here is a little example plugin that uses the CloudFileManager, Properties, RaspiCam, Logging and MQTT functionality provided by the plugin API.
When you publish a string representing the desired file name into the topic home/room/picam/upload, this plugin takes a photo with dimensions and quality as specified in the PiCamUpload.properties and upload it to dropbox. If "current_time" is sent , the current date and time will be used as file name.
public class PiCamUpload extends BasePlugin {
@Override
public void onStart() {
// get CloudFileManager implementation from plugins (dropbox in this case)
CloudFileManager cfm = getSystemManager().getCloudFileManager();
Objects.requireNonNull(cfm, "A CloudFileManager implementation is needed for this plugin to work.");
// get properties from this plugins's .properties file
int width = Integer.parseInt(getProperties().getProperty("width"));
int height = Integer.parseInt(getProperties().getProperty("height"));
int quality = Integer.parseInt(getProperties().getProperty("quality"));
// subscribe to a fitting topic
MQTT.get().subscribe("home/room/picam/upload", (MqttMessage m) -> {
// convert binary payload to ascii string
String filename = new String(m.getPayload(), StandardCharsets.US_ASCII);
if (filename.equals("current_time"))
filename = new SimpleDateFormat("yyyy-MM-dd_HH:mm:ss").format(new Date());
File img = new File("./" + filename + ".jpg");
try {
img.createNewFile();
} catch (IOException e) {
getLog().error("Exception", e);
RaspiCamera.take(img, width, height, quality);
try {
cfm.uploadFile(img, null);
} catch (FileNotFoundException e) {
