A quick project spending next to nothing to provide a late night reading lamp
Bend the coathanger into the shape you want
Solder LEDs, resistors etc onto a bit of veroboard. I used a female PCB header for plugging in the battery so that I didn't have to route long cables around the frame. Leave some length on the LED pins so that they stand up a bit from the veroboard
Fix your battery holder to the coathanger. I used sticky tape so I can easily remove it when the batteries go flat
