I created this project to Hackaday.io and typed in a small summary of project logs. The project seems to be very promissing so why not get the word out. The software version is at 0.71 and has the following features:
- On The Air webupdate
- I can flash the ESP8266 with a new firmware straight trought the web-interface
- Settings-page for the variables
- "Trigger minimum", "Trigger maximum", "Number of pixels", "Light up delay" variables can be changed from the web interface
- Led strip now triggers if the measured distance is between the minimum and maximum. The led strip pixels are lit up sequentially using the delay value
Timo Hyvönen
