Here is a proof of concept python script
First, you need to have the python-rpi.gpio and omxplayer packages installed
sudo apt-get install python-rpi.gpio omxplayer- check that your configuration match the script settings and edit accordingly,
select a short video clip (like this one) and edit the lineVIDEO_FILE = '/home/pi/video/better-than-tv-ads.mp4' - start the script :
sudo ./switchdemo.py - this should select the STB output
- press button 1 on your switch remote
- your video clip should start playing
- at the end of your video clip, the script will switch back to your STB input
The next step should be to integrate this script with Kodi to have a nicer user experience.
PixJuan
