Sensor
To detect the state of each opening and to keep that as hidden as possible, I choose the A3144 Hall Effect sensor. They are stuck on the top and/or side of frames before the insulation and the dry wall are put in place. An advantage of these sensor is there robustness, a wide voltage input range and a protection against wire inversion.
Sensor on the top of the frame of an inside door
Sensor on the top of the frame of an aluminum window
As we only have a weekend to do it and I don’t find my heat shrink tubing, we solder and silicon sensors. We use telecom cable for wiring.
A neodym magnet stuck on the moving part make the second part of sensors.
One sensor on the top and one on the bottom to detect window 3 different states
Power Supply
Two different power supplies with hot swapping thanks to 2 diodes. The 3.3V regulator was not on the board because I already have some small board for this purpose and I only want one regulator for all the inputs boards.
Alarm part
The independent part for the alarm is based on 8 OR/NOR gates chained with diodes. This allows to put several boards in parallel to trigger a single relay. Some sensors can be excluded from the alarm loop with solder jumpers.
Web Enabled part
The brain of this is the Rpi with the help of some I2C IO expanders (PCF8574)
Schematic
Some room was remaining on the PCB so I put 2 small boards, an I2C temperature sensor and an interface for an electric metering system.
Schema
Schema
Two layers PCB
Two layers PCB
Top & Bottom of the PCB
Manufactured PCB
Manufactured PCB
I2C Buses are linked, the interface to an external alarm is only populated on one board and the other board use it too.
Enclose
The 2 boards are put in a DIN Rail enclosure with the Rpi.
I use a bread to add 2 status LED and the power connector.
Enclosed Board
Enclosed Board
Final result
Final result
