NodeMCU DEVKIT V1.0 LiPoly LiIon Backpack Rev.A
Add a rechargeable battery to your ESP8266 NodeMcu v1.0
This is a LiPoly backpack designed for the module NodeMCU ESP8266 v1.0 this expansion allows the module to work with LiPo battery and charg
This is a LiPoly backpack designed for the module NodeMCU ESP8266 v1.0 this expansion allows the module to work with LiPo battery and charge it if you power up your ESP8266 by the USB port.
If you have a NodeMCU ESP8266 v1.0 you probably know it's the perfect little size for IoT projects. This LiPo backpack makes very easy the charge of a LiPo battery instead of soldering more boards, this little PCB sits on top of the NodeMCU ESP8266 v1.0 and allows a LiPoly/LiIon battery to plug in. When the NodeMCU ESP8266 v1.0 USB port is powered, the battery is recharged automatically. Unplug the USB port and the NodeMCU ESP8266 v1.0 will switch over to the rechargeable battery.
This backpack is the first one designed for the module NodeMCU ESP8266. Automatic switch between charge and use of the battery. It has a jumper to control the current to charge
Buy in Tindie
View all 3 project logs
