Looking at ways to maximize the usefulness of the space provided by the stability frame.
To the right of the machine, the space provided by the frame will accommodate the power supply needed to power two heat beds, the hot end and all motors etc.
To the left, I am looking at ways to mount a filament spool holder to the frame. The weight of the filament will help to stabilize the unit against X-Axis movement of the bed.
