Bearings on board...
A project log for Printrbot 'SuperSize Me" Mod
Transforming the humble 150x150x150mm stock print bed of a printrbot simple metal to a whopping 500x500x150mm
kendoken.do • 03/29/2016 at 23:45•0 Comments
Ok... so the printing bushings didn't work out.
I finally got some 12mm linear bearings and tried installing them without modification. The 12mm bearings are quite a bit longer than the stock 8mm bearings, so they didn't fit in the frame holes (this was expected). I designed and printed some cradles that slot into the holes in the frame to hold the bearings in place. These are the originals:
Great idea! But there were some issues. The insert bit fit too loose, one cradle interfered with the endstop switch, and the whole cradle stuck out too far. A quick redesign and reprint, and everything fits. But the end of the x-axis rails no longer connects with the endstop before it hits the bearing. I drilled a hole and put in a machine screw to hit the endstop switch and voila! Success.
First print was the other x-axis end. Seems like I have reduced but not eliminated the jiggles... yet.
