First up is getting the USB to Serial working on this device. After some research and trying every other driver in the book, I found that the board uses the CH340G chip from WCH Co Ltd. I was able to find a driver here for OS X El Capitan.
I'm pretty sure this is the right driver but I'm about to reboot to try it out.
stopsendingmejunk
