The git repo is now up with the up-to-date board design. The nRF components are verified. So if you would like to use the nRF chip in your project you can clone this repo and pull the part out.
A project log for BLEezy: Raspberry Pi Zero
An easy to use BLE module for the Raspberry Pi based on the nRF51x chipset
