When I make something I generally go into it to learn something. Another thing I want to learn out of this project is how to make the toolchain simple. After some advice and poking around I have found a solution for programming the BLEezy. It will use mbed, OpenOCD and the Raspberry Pi. I have already written the installer scripts now I am working on the programming scripts.
(write project on mbed.com) -> (Download hex) -> (run python script to install hex on BLEezy) -> Done!
