Yesterday I tried to do Schlieren in fluids and it works just fine!
As fluid tank I used an etching bath, filled with water. I placed it between the camera and the Moiré pattern.
To create some turbulence in the water I added some Isopropanol and later also Salt. Here is a video of the result with the Iso.
More and better results will follow soon!
Jana Marie
