Just made a quick comparison video, of a torch, recorded with the Moiré pattern and then also the difference to the reference image.
Sadly the lightning wasn´t that great, so it didn´t turn out that good, but its okay.
Schlieren on the left, normal Image on the right.
You can hardly see the air density change on the right, with the calculations and rework done on the left, a little bit better.
Jana Marie
