Even if you think that your setup is perfect, it isn't. I just remade my setup and figured out which two things are most important.
Thing 1:
Light, you will need an even proper lightning, otherwise you may have a bad effect or even ghostings.
Thing 2:
A good distance, play with that, it took me serval attemps to find a nice distance.
