Building LED cube based on #LED Polyhedron by @Daniel Rojas
I did changed Daniel's example Arduino code a little bit to make it run with a cube. I used a Arduino Nano clone to test it. The idea to make forms based on squares is not so good. The structure of this cube is very weak and you should handle it with much care when transporting it. Here I little video in the dark:
