Well it's been one month since I got my Backplane board so its time for an update.
How well has it lasted?
The Answer is, great! So far the gateway has been running for about a month with the downtime only being from where I've been tweaking the software or power cuts.
Otherwise I have two gateways running using this board, one RAK831 and the other ic880a and both are working ideal.
Modifications Planned
Currently I have the following modifications planned:
- Add USB Ports - I'm planning to break out 2 of the USB Ports from the Nano Pi Duo
- Add Barrel Jack -
- Move Mounting Hole
- Modify Silkscreen
- Still undecided - Change to use a switching regulator
And that's it for now!
