To have the possibility to measure the remaining power of the LiPo it is more accurate to measure the voltage of each cell in parallel with the current.
A simple algo regarding the typical V=f(I) of the LiPo will give an idea about the remaining charge.
The voltage of the cells, the current and voltage provided by the LiPo are sent to the PCB TOP using a 6pins connector.
