Here is the interfaces regarding the power needs/uses and the front sens connector.
It describes the connector used in the TOP PCB.
There are mainly three types of connectors:
- JST/Molex 1.25mm like 6p
- JST/Molex 1.25 like 3p
- PFC connectors for the RPI CAM sockets and for the front sens panel
The power of the RPi CAMs are not represented, they are directly distributed by the compute module.
