Hackaday.io Hackaday.io
Sign up Log in
ESP8266-07 Breakout
A breadboard friendley Breakout for ESP8266-07 modules with some extra functions.
jan-bJan B.
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.5k views
2 comments
10 followers
  • Description
  • Details
  • Files 0
  • Components 12
    • View all
  • Logs 3
    • View all
  • Instructions 0
  • Discussion 2
View Gallery
1.5k
2
10
6
Team (1)
  • jan-bJan B.
Join this project's team
completed project
hardware
ESP8266 breakout BREADBOARD
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 01/03/2016 and last updated 10 years ago.
Description
A ESP8266-07 Breakout for Breadboards made with KiCAD.
Features:
- Onboard 3.3V regulator
- can work with TTL Serial
- Reset and Programm Mode directley over the Serial header (based on: http://nerdralph.blogspot.de/2015/04/zero-wire-auto-reset-for-esp8266arduino.html)
- Voltage divider for ADC with max. 10V
- Reset Button and Pin Header to enter Programm mode manually
- on board LED on GPIO4
- Size: 50x32mm
Download files : https://github.com/do9jhb/ESP07-Breakout
Components
  • 1 × ESP8266-07
  • 1 × AMS1117-3.3V 3,3V LDO
  • 1 × Push Button
  • 1 × 3V3 Zener Diode
  • 1 × 2mm LED
View all 12 components
Project Logs
Collapse
  • Please Share your Experiences!
    Jan B. • 03/11/2016 at 15:58 • 0 comments
    When someone has built the Breakout, please share your experiences in the Comments, so I can improve it.
    Thank you!
  • It works!!
    Jan B. • 01/10/2016 at 12:51 • 0 comments
    After some issues with the Auto-Reset Circuit, it now works very well :)
    And so its looks in real :
    Here are the Layout files :
  • Schematic and PCB finished
    Jan B. • 01/04/2016 at 11:51 • 0 comments
    I have finished the PCB and the Schematic. The next days I will try to etch a PCB and build one.
    Here the Schematic:
View all 3 project logs
Log In/Sign up to comment
Sign up with Github
OR
Jan B. wrote 03/23/2016 at 19:59 • point
Thank you ;)
Yes I know that putting parts under the antenna is not the best solution, but I did not have so much space on the PCB and I thought that the best RF emission is not the main criteria for a breakout board...
And yes it works :)
Elliot Williams wrote 03/22/2016 at 09:05 • point
Great looking breakout.
My only critique is that the antenna part of the module should probably be as far from any metal parts as possible -- ground planes and components on the underside might influence the antenna / propagation.  Of course, if it works, it works.  :)
A compatible cheap and fully working Arduino board with a lots of traces and schematics. This is one I want for my projects.
Project Owner Contributor
I Made My own ARDUINO Uno Board
electroboyElectroBoy
Supplyframe DesignLab: 2023 Hackada…
In this tutorial, I am going to show you guys how to design this "Transformers PCB Badge" and how to solder the components to it.
Transformers PCB BADGE
hulkHulk
My variation of the geeky Christmas decoration made out of PCB
PCB Christmas Tree
olekOlek
Yep, a Nano with c type and compatible drivers is what I want for my projects. Get it now on PCBWAY the clone board
My own Arduino Nano Microcontroller board
lithium-ionLithium ION
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "ESP8266-07 Breakout", please tell us the reason.
Send message
Remove Member
