LEDBrick Reef Aquarium Lighting
An emitter + driver + controller board stack for Reef Aquarium lighting
An aquarium LED lighting setup using custom PCBs
  • 8 channel custom LED emitter board for UV, Blue, Royal Blue, White, Green, Red, PC Amber and Cyan
  • 8 channel Texas Instruments LM3414 driver board with stacked header for a control board. 24V main power input
  • Bluetooth Low Energy nRF51 based 8 channel PWM light controller board with 12V fan header.
Available under the CERN license.
https://github.com/theatrus/ledbrick
PCBs pre-loaded into OSHPark:
https://oshpark.com/shared_projects/EGdurbme
https://oshpark.com/shared_projects/7uwwfspd
ledbrick_pwm.PDF
Schematics, BOM, and board layout images
Adobe Portable Document Format - 3.12 MB - 01/16/2016 at 07:03
Preview
  • 1 × 4.6" Serated HeatsinkUSA.com Profile in 4inch width
  • 1 × 80mm thin fan
  • 8 × LM3414 Interface and IO ICs / Display Interface
  • 38 × High power (3W) LEDs in Rebel ES, Cree XP, Oslon Square and Rebel UV footprints
  • 1 × nRF51822
View all 6 components
  • Bluetooth LE controller board firmware
    Yann Ramin01/21/2016 at 16:44 0 comments
    Firmware for the Bluetooth LE board is now available on GitHub: http://github.com/theatrus/ledbrick
    PWM setting, fan and temperature monitoring are both supported, with a fan-off failsafe. Temperature fail-safe and fan-spin-down is coming soon.
    I'm also working on the BLE central controller, running on an RPi. Updates on that soon.
  • Acrylic case
    Yann Ramin01/21/2016 at 16:38 0 comments
    Spent some extra time on the outer acrylic enclosure design - all the intake is on top, and the exhaust vents have been extensively restyled with a nice wave motif.
    Laser cut from 1/8" acrylic.
    Also added a fan shroud to prevent internal air recirculation from the heatsink. The 80mm fan sits directly on top of this (spaced with rubber washers)
View all 2 project logs
