- Titan Y6 frame (new!)
- KK flight controller (pulled from previous build)
- 6x 30A speed controller (pulled from previous build)
- 6x 2212 1000KV motor (pulled from previous build)
- 6x 10x4.5 props (pulled from previous build)
- X8R receiver (pulled from previous build)
- 4400mAh 3S battery (pulled from previous build)
I'm not sure about this motor/prop and battery combination but I'll give it a try. Might need to drop KV and possibly move everything to 4S.
Gimbal gamble- 2-axis gimbal frame (new!)
- 2x 2208 gimbal motor (new!)
- Martinez gimbal controller (new! with power from battery)
Gimbal tilt will be wired up on a Taranis channel.
GoPro or go home- GoPro (new! with power from internal battery)
- GoPro video out connector (new!)
- 600mw 5.8GHz Transmitter (new! with power from main battery)
- 5.8GHz Receiver (new! with power from 1100mAh 3S battery)
- 5.8GHz cloverleaf antennas (new!)
GoPro video out looks like a mess but I should be able to get something working.
