I stayed up late last night reworking these ESCs. The electronic speed controllers came with huge balls or solder. I want to have as many direct connections as possible so I removed the wires and solder for new connections.
Wires removed.
Most of the solder cleaned up. I used a suction and wick to remove as much as I could.
All ready for new wires. Hopefully they still work!
Richard Hogben
