Success, and a bit of failure
A project log for Model Train Controller
A digital model train controller for those who still want an analog world.
john-spencerJohn Spencer • 04/24/2014 at 04:04•1 Comment
While I'm posting this at the same time as the rest of the project, I felt it deserved it's own log entry.
Dad's new trains worked great with this controller.  They were slightly slower, but the acceleration effects worked and they still had the torque they needed.  We needed to bump the speed up to break the initial rolling resistance before setting them to a slower setting, but that was expected.
The older trains though, they were very slow.  Needed to set them to full power to get anything out of them.  With the older controllers they HAMMERED around the track so we decided to do some digging.
The older controllers have the text "OUTPUT: DC 11.6v, 0.36A" on the case.
First we checked the current with a multimeter in series.  Fortunately, both the old and new controllers outputted around 0.36A, indicating that was about what the train should be drawing.
Then we checked the voltage, and what a surprise there.
The new controller outputs 12V in pwm.  It is always at 12V, no drops, no spikes, boring.
The old controller is all over the place.  At full power it was consistently at 13.5V, but anything less than that and it fluctuated between 3V and 24V.
So, from here I'm going to try a higher rated power source.  The system can take up to 28V, but I think I'll go for 14 to 15V.
Paul Antoine wrote 06/15/2021 at 01:44 • point
Hi... an interesting read, and so nice to see you doing this for your dad!
I've been working on microcontroller based DC model locomotive control for a while now. A long time ago I came across the link below which looks at the actual performance of old-style DC train controllers like your dad's old one... thought you'd be interested in the content re voltages, waveforms and such.
http://www.scottpages.net/ReviewOfControllers.html
