I had trouble with the keyboard code so I went back to working on the mouse part. I got it working almost the way I want it with help from someone on reddit. The mouse works after playing around with the sensitivity value in the code. At first the pointer moved really slow. I lowered the value to around 25 and it moves fast enough but now the pointer wanders a little. The left and right click buttons are working.
So back to the keyboard, I have worked out the pin mapping for the keyboard to teensy connections and I did some work on the matrix and the different states (shift, fn..) for the button presses. These are the pin mappings
columns: keyboard pin | teensy pin (with arduino pin numbers)
1 | 27
2 | 0
3 | 1
4 | 2
5 | 3
6 | 4
7 | 5
8 | 7
9 | 8
10 | 9
11 | 10
12 | 11
13 | 12
14 | 13
rows: keyboard pin | teensy pin
A | 22
B | 21
C | 20
D | 19
E | 18
F | 38
G | 39
H | 40
I | 41Hopefully that makes sense. And here is the matrix. I don't know how to paste it without it getting all jumbled so I'll post a screenshot.
I will continue to work on this and hopefully learn how to get it working.
pdrift86
