Learning how to use Fritzing in order to create a small perfboard to test the high-voltage part on the 300W halogen lamp.
A project log for MQTT WiFi controlled mains halogen dimmer
MQTT WiFi controlled mains halogen dimmer that can be controlled by rotary controller or from home automation (OpenHab) by PIC and ESP8266
