I might be falling into a pattern...
For now I just want to collect all the sources in one place. The list is somewhat sorted but hopefully I'll go over this list again and summarize all/most of them and maybe do some more sorting.
A quick heads up: There are a lot of duplicate links but I wanted to document for myself how/where I found the projects.
Hakko 907:
- I already mentioned this one which was featured on the blog - I really like the option of driving two irons and the author makes a good point for the analog dial. He also proposes a mod for better heat conduction between the heating element and the tip.
- Right now I'm thinking whatever I'll end up building is going to be very close to #Hakko 907 based Soldering Station because it's very straight forward.
- http://elco.crsndoo.com/wordpress/2012/01/soldering-iron-driver-gen3-rev1-4/, via http://dangerousprototypes.com/2011/10/25/hakki-907-and-compatible-soldering/
- #Soldering Iron Controller - (light on info) / more info: http://www.zl2pd.com/SolderingStation.html - (analog & digital control), via http://hackaday.com/2015/09/02/a-tale-of-three-soldering-iron-controllers/
- #Mobile temperature controlled soldering iron - links for components
Hakko T12
- http://dangerousprototypes.com/forum/viewtopic.php?f=56&t=5264&start=180#p58264 / http://dangerousprototypes.com/2014/07/01/hakko-t12-soldering-controller/
- #70W Soldering Iron Controller / http://smdprutser.nl/project/70w-soldering-iron-controller/
- @Stefan Wagner's #Soldering Station and #TinySolder
Weller RT:
- http://www.martin-kumm.de/wiki/doku.php?id=Projects:SMD_Solderstation, via http://dangerousprototypes.com/2014/05/29/smd-soldering-station-for-weller-soldering-tips/
- https://debugginglab.wordpress.com/2014/10/30/soldering-station/ / https://github.com/ConnyCola/SolderingStation - based on above, very nicely thought out (has standby feature), PCBs on DirtyPCBs
- http://hackaday.com/2015/05/11/hacking-amazing-soldering-features-into-the-already-great-weller-wmrp/
- #Soldering pen by @HP (@banjohat) - also based on the one by [Martin Kumm] linked above, very cool idea of integrating all the controls in the handle, made me think about applying this concept to the 907 iron/handle
- See also the projects in @Teslafly's list rt usb_c soldering iron
Weller WSP80:
- http://www.eosystems.ro/index.php/projects/esol - uses MCU's internal PGA
- #Yet another DIY soldering station by @SUF - expected to have 3 (!) soldering irons and a bunch of other useful features, especially like the ideas to reduce energy consumption
Modded mains soldering iron:
- https://pcbsmoke.wordpress.com/2015/10/03/diy-110v-temperature-controlled-soldering-station/, via http://dangerousprototypes.com/2015/10/05/diy-110v-temperature-controlled-soldering-station/
- https://pcbsmoke.wordpress.com/2015/08/03/soldering-iron-temperature-controller-version-2/
- https://pcbsmoke.wordpress.com/2015/07/12/diy-digital-soldering-station/, via http://dangerousprototypes.com/2015/07/14/diy-digital-soldering-station/
- https://pcbsmoke.wordpress.com/2015/06/04/soldering-iron-pulse-timer-temperature-control/, via http://dangerousprototypes.com/2015/06/05/soldering-iron-pulse-timer-for-temperature-control/
- https://pcbsmoke.wordpress.com/2015/04/21/soldering-iron-pid-temperature-controller/, via http://dangerousprototypes.com/2015/04/27/soldering-iron-pid-temperature-controller/
- #Entry Level Electronics -- Improve your Iron
Misc:
- http://poormanelectronics.blogspot.ro/p/pm-soldering-station.html
- http://dangerousprototypes.com/2016/02/03/unisolder-5-2/ - universal controller
- @monsterome's list SOLDERING STATION DIY
While I focused on soldering stations here, you might also want to check out the official soldering-tools list if you haven't already.
Edit 2016-03-28: Added #Soldering pen
Edit 2016-03-28 #2: Added http://www.eosystems.ro/index.php/projects/esol
Edit 2016-05-07: Added #Yet another DIY soldering station
Edit 2022-09-05: Added links to curated lists and some more projects
Stefan Lochbrunner
Thank you for sharing ! :-)
