I name thee NANO-4096
A project log for NANO-4096
An easy to build Arduino based gaming device with 101x80 pixel 4096 color LCD, 8 buttons, sound and SD card.
maarten-janssenMaarten Janssen • 01/31/2016 at 16:56•0 Comments
I finally came up with a name for the device: The NANO-4096. The past two weeks I've spent more time on the code. I decided on using the SdFat library for SD card functions. It's slightly more compact than the standard Arduino SD library. I've also finished the demo game Heartlight! The levels file from the original game is read from the SD card which means that all 70 levels from the original game are playable on the NANO-4096 :D. It needs a little more polish, for example being able to select a level and a real intro screen, before I'm fully satisfied with it. There is still 5kb left for these features, which should be plenty.
I've also decided to ditch the analogue stick. It was making the device quite bulky and the analogue travel of the stick was almost non existent. So I've replace the stick with four buttons. Still the X and Y-axes are hooked up to separate analogue inputs (A0 and A1 respectively) allowing the player to press two direction simultaneously. This change lead to me making a new prototype on a slightly bigger board. Build instructions on this page still need to be updated and I will provide a video soon of the NANO-4096 in action playing Heartlight.
