Filled in Credential details, bolted up the Responders and some UI components to show FloatVariables returned by ToneAnalysis
Generally the UI element is Lable and one of Hipple's bar graphs. The Joy element also adds a Value display in Text field. I like this and should examine in detail for use as prefab with one script filling in the Name, Text Value, Graphic components.
The Credentials work well. I definitely prefer the TA approach using string properties over the other that uses StringVariables. It keeps them close in one display, vs inspecting several components.
