Took the Joy element from last revision and tweaked it a bit, then saved back to prefab and repositioned others.
New style uses the Panel's Text element to display a label, and a UI.Text element to display the value within the Filled element. New script supersedes both Hipple ImageVar slider and the previous SOUI element.
Jerry Isdale
