First Part of Build
A project log for Die Brücke
The modular, easily disassembled, yet sturdy executive style Command Center Desk
yonghanYonghan 03/09/2016 at 06:440 Comments
The first module in the grand scheme of things... the center module which would house two computers.
This is the panel with 4 120mm case fans and filters which will be installed under the module. The idea is to create an upward air flow which is also where hot air goes... so the system will use less energy to cool down.
Rich text editor
