I tried out the plastidip on the body and so far it looks pretty cool and if I want to repaint or change colors it is certainly easier than sanding! In this pic i also fitted some sensors in front of the wheels as non touch bump sensors. Also there is a voltage gauge that is black when not lit.
The plastidip can be used to protect electronics from moisture so I am trying that out on a sensor and leaving it outside in the rain.
