For obvious reasons I removed the Velcro dots and put in some quick fasteners on the mounting tabs. I drilled holes and not I can screw down the deck lid so that someone cannot just pick it up and see the electronics inside. As of now they are Phillips , but I will swap to a security key bolt once things are running smooth.
Josh Starnes
