The Pi Board before the heat sinks
After applying 5 aluminum heat sinks. I used thermal pad that is similar to a putty to stick them on. the main processor has 4 of the 10 x 10mm heat sinks. the smaller chip which I believe is the ram only has one.
A project log for Watchdog Security Camera Robot
Solar charges, Open build, affordable, watch and report or community presence robot.
The smaller chip is the USB hub and Ethernet adapter. The ram is integrated into the main chip along with the CPU and GPU, which is why it's called a System on Chip (SoC).
